Group: DynoMotion Message: 6570 From: Matt Parker Date: 1/23/2013
Subject: Fw: [DynoMotion] Anilam conversion help
Sent: Wednesday, January 23, 2013 9:47 PM
Subject: Re: [DynoMotion] Anilam conversion help
Hi Tom
I have made some progress. I found and rectified play in the thrust bearing that has made things a lot better. I can get the axis stationary with no motor noise. The motion is still unstable. Please see attached pic. This was with the motor amp in torque mode as still can't seem to get it stationary in velocity mode.
Many thanks for your advice
Kind regards
Matt
Sent: Wednesday, January 23, 2013 3:18 AM
With glass scales it usually helps a lot to have some feedback from the motor shaft (tach).
Do you have the AMC amplifier in velocity mode?
You will likely need some D gain to help stabillize the system.
Post some screen shots so we can see your settings and the response you are getting.
You can use Alt-PrintScreen to copy a Window to the clipboard.  Then paste into something like Paint and save to a .png file.
We need to see the Step Response, Filter, and Config/Flash Screens to see all your settings.
